At 8-30am this morning presented my, recently acquired, 206cc for its M.O.T. at our local ATS.
Soon after starting the probe went into the exhaust, 2 minutes later massive sigh of relief as all green lights, emissions are good straight away. Well worth doing oil and filter change before MOT.
Next, it's up in the air, front end checked and nothing seems wrong. The back end was then jacked up and after probing and squinting all around the examiner pointed out to me that the back tyres were virtually touching the plastic of mudguards at the front. Checking tyres we found that the car had been fitted with 195/65/15 tyres, according to the door ticket they should be 195/55/15. The tester then said about the plastic rubbing on the tyre and could cause wearing, he would not fail it but I needed to be aware. With that, the car was lowered off the jack and suddenly the gap in front of tyres was over an inch. No issue but questionable about tester?
So after all that M.O.T. over car passed with 1 advisory, coil springs have surface rust.
Overall what a great day, especially as the car, is a March 2003.
M.O.T.
MelidenBob
Re: M.O.T.
You might have wear in the bearings in the suspension arms ... the ones the wheels are mounted to .. that would mean the wheels "float" about a bit. If he pushed the car backwards then this would bring the tyres closer to the inner wheel arch. 55 to 65 profile isn't the issue. Trying to move them by hand often doesn't show the wear up .. but you can see the wheels are the wrong angle .. and if they are touching the inner wings, they are definitely out.
He's definitely missed a potential problem there ..
MelidenBob
Re: M.O.T.
Thanks for the reply.
I think you have misunderstood, when I say about the wheels almost touching it is when the car is jacked up and when the suspension arm lowers down allowing the wheels to move forward so that they are close to the corner of the sill.
Re: M.O.T.
But they shouldn't touch the inner arches in either position ...
Slo
Re: M.O.T.
Easy test is to see if you can get your fingers between the rear inner tire wall and inner wings.
You should be able to slide your fingers past easily, if you cant get your fingers in its a sure sign the arms and bearings are wearing out.
Re: M.O.T.
I think the tester was being fair
