Hello
As usual, I've been tinkering with bits and bobs around the fuse box under the steering wheel and I've discovered this white wire with connector dangling! See the picture attached.
Where is it supposed to be plugged into? I'm not sure if I pulled it out myself accidentally or if it was never plugged in to something in the first place. Bit concerned it's for something important...
My cc is 2004 1.6 petrol (TU5JP4).
Thanks in advance
George
Where is this white wire supposed to go??
George 206cc
Re: Where is this white wire supposed to go??
Any identification marks (numbers or letters)?
George 206cc
Like these? Do these help?
It could, if I could find it in the SEDRE, but I've drawn a blank. At a guess, it's not used.
