HELP! What is this part called?
zaqxsw
Post by zaqxsw »
Hello,
I need your assistance here.
Could you please tell me what is the name of the part depicted in the picture below?
I think the bump I see is due to corrosion of the aluminium , if that thing inside is aluminium.
Has anyone experienced something like that?
Is that fixable?
Thank you!
Re: HELP! What is this part called?
I think it's the DOOR WINDOW JOINT:
9309 E3 LEFT
9310 C3 RIGHT
Apparently, it's impossible to get them off a donor car without bending them, and once that happens they are useless.
Mine have the bumps - I think it's fairly common. I just live with it.
It's more likely to be thin steel as they rust ... that's the bumps!
This site may have them, but the list was from Mar 2018 and at that time the right one showed 1 in stock.
http://www.peugeotparts.co.uk/page18.htm
zaqxsw
Post by zaqxsw »
Thank you all for your useful answers!
Is there any online shop to purchase them because in Greece the official Peugeot dealer sells them for 160 euros plus shipping cost.
I don't think peugeot make them now
MartinMax
Post by MartinMax »
So has anyone had any info on repairing them?
@IanL, thanks for the heads-up on not removing them as I was about to pull them out and at least try to clean them.
The bumps are not so much of a problem, but the gap between the rubber and the glass will let water in.
Can that damage the inside of the door?
Also on mine, part of the metal is visible on the inside and it might scratch the window, so any ideas are more than welcome...
2001 206cc 2.0 S16
