TU5JP4 Valve Gasket Replacement?
gpktm
Post by gpktm »
Hi all
I have a problem with my TU1JP engine. There is an oil leak from the top gasket (not the head gasket). I am trying to find the replacement part but the results come up refusing. I looked up for "Valve gasket" and I managed to find few different gasket shapes. Can anyone help out?
The car is a 2006 Peugeot 206cc 1.6L Petrol 16V TU1JP
I have uploaded a view showing the spark plugs being flooded with oil from the leak caused.
https://youtu.be/3JCadjNfqOM
Re: TU1JP Valve Gasket Replacement?
The TU1JP engine is 1124cc, not a 1.6. The 1.6 engine in 206CC is TU5JP4.
My 2005 TU5JP4 top "gaskets" (the Peugeot name is oil separator plate) are Peugeot Part No 0249 C6.
If you do have a TU1JP engine (how?), the gasket is 0249 54.
gpktm
Post by gpktm »
IanL wrote:The TU1JP engine is 1124cc, not a 1.6. The 1.6 engine in 206CC is TU5JP4.
Hi Ian. Sorry, my bad. I've probably copy pasted the engine model without realizing it was wrong, I've just noticed now! You are correct, the engine is TU5JP4. :)
Thanks for the part number by the way :)
