I need some help please. I have a 206 cc 54 plate.
Last week I changed the spark plugs. Everything was ok for a week and today the engine light came on with a message on the centre display..... ANTI POLLUTION FAULT etc...
I checked error messages using the OBD and the error code is P0402
Not really sure what that is and how to fix this matter.
Could I have used the incorrect spark plugs?
Any help much appreciated.
Engine light on & ANTI POLLUTION MESSAGE
Re: Engine light on & ANTI POLLUTION MESSAGE
P0402 is a problem with EGR (Exhaust Gas Recirculation), so nothing to do with spark plugs. It could be the EGR valve needs cleaning.
amebb
I will get some egr cleaner tomorrow and give it a good clean.... fingers crossed it will do the trick.
Thank you for your response.
amebb
Update..... the other day I put some petrol in the car.... I put the expensive fuel in with all the additives.... after 10m8ns the light was gone.
Thank you for all your help.
