Can a radio be changed from one vehicle to another
- Fihen
Hi all hope this is not a silly question but I have access to a radio unit from a 2007 206 hatch and am interested in putting same into my 206cc. From what I read from the owners (hatch) manual they cannot be put into another vehicle. This doesn't make sense to me so I am asking the forum for an opinion before I go to a lot of trouble only to find the manual is right.
Re: Can a radio be changed from one vehicle to another
If they are the same type of radio, there will be no fitting problem, but the replacement radio must be "programmed" with Peugeot Planet to accept the car's VIN. If this is not done, it will work, BUT there is a fairly frequent beep on the sound that cannot be removed any other way.
Planet is a combination of special hardware interface (Proxia/Lexia 3) and software which runs on a 32-bit (NOT 64!!!) Windows PC. See here for more. You can also buy it on eBay, if you want to have the manufacturer's diagnostic system available when needed. Or, for an arm and a leg, you can go to a Peugeot dealer to get it done.
- Fihen
Thanks IanL the previous owners of my pug have bastardised the radio and have cut all the wires to remove the oem radio and have put an aftermarket radio that doesn't even fit the dash properly and looks ugly. I will go ahead and get the radio fitted thanks to your advice.
- MartinMax
@Fihen
If your car is of an earlier year <2002 check if the radio will work on a non multiplexed system.
2001 206cc 2.0 S16
2001 206cc 2.0 S16
Post 2002 radio will not work on pre 2002 car.MartinMax wrote:@Fihen
Why do people butcher the wiring? Laziness, ignorance?
