rear windows
micky1
rear windows
hi guys I have a 2005 206cc 2.0L allure and the rear drivers window doesn't go up properly it goes up at an angle and some times sticks and then you have to pull it the rest of the way up with your hand thinking of going to breakers yard to see if can get one is the motors all the same on all Peugeot electric windows thanks micky1.
Re: rear windows
I think the rear motors are unique to the 206CC.
People with that problem have recommended lubricating the window seals, either with silicone spray or candle wax, as the problem is usually caused by excessive friction between seal and glass.
