206 cc 1.6 53 plate sump drop
Carst
Hello everyone, I am currently trying to fix my wife's cc which has a leaking sump and also has a broken bolt that I can't get to without sump removal. I have tried the search function but I'm still struggling a little. I have the sump loose now but it is now hitting the lower engine mount, once this has been loosened is there enough movement in it to finally remove the sump, bearing in mind the drive shaft also runs through it?. Any help would be greatly appreciated. Thank you.
Carst
Re: 206 cc 1.6 53 plate sump drop
All done now, wasn't a bad job but the lower mount/stabilizer makes it difficult to remove and replace, I also had to remove and re seal the filter housing bracket.
Well done.
