When closing the roof, after locking the latches...
Are you imagining a 'race to close' between the left and right window?
I know I do, and the left window always wins :-)
Are you doing this?
- MartinMax
Are you doing this?
2001 206cc 2.0 S16
2001 206cc 2.0 S16
- rhume
Re: Are you doing this?
I find if I try to close both at once then it all goes pair shaped
The left always wins because it starts first. Probably deliberate, as the winding motors take more current when getting up to speed, so a staggered start is good practice.
- MartinMax
Probably there is some reasoning behind it...
But the hope that 'Righty' will eventually win is still there :-)
2001 206cc 2.0 S16
2001 206cc 2.0 S16
Luditus
Out of curiosity, I decided to try the "Window Race" today. Result..... a dead heat!
Was that going up or down? I get a win for left going up, but a dead heat going down.
Luditus
I didn't realise there was a "going-down" race too! Going-up includes the rear quarter lights sprint prior to the long slog of the main windows on the home straight. (My race was carried out with the engine running.)
Do I detect a new Olympic sport in the offering?
- rhume
If we are using the running analogy!! If I do both of mine at the same time sometimes one of my rear windows falls at the final hurdle and doesn't get over the finish line. The front one then charges off before the baton is passed therefore being disqualified.
If the windows are done Separately this never happens.!
- MartinMax
Give that window some motivation with a bit of silicone lubricant...rhume wrote:If we are using the running analogy!! If I do both of mine at the same time sometimes one of my rear windows falls at the final hurdle and doesn't get over the finish line. The front one then charges off before the baton is passed therefore being disqualified.
2001 206cc 2.0 S16
2001 206cc 2.0 S16
- rhume
Yep. It has been lubricated and all close perfectly if done one at a time. If both done at the same time the voltage drop seems to lead to the occasional early stopping of one of the rears.
Does it happen with the engine running?
- rhume
yes. always tend to do roof and windows with engine running. It really is a bit of a first world problem though
