206cc 1.6ltr low power to fan causes No start
shimerin
Post by shimerin »
206cc 1.6ltr
My motor has a on/off issue, A few weeks up to it not starting it has a very rough idle, it starts rough and press the accelerator nothing no revs this is for about 30 seconds then it revs but still rough idle a few minutes go by and it can be drove without issue as time goes on it happens more often until on start up it starts but cuts out every single time, will not start on a bump start or jump start on a diagnostics computer the only fault showing is (low power to fan) I have no idea what fan it is talking about radiator fan works 100% battery is 4 months old. The past 4 months the diagnostis`s guy has cleared the fault and it works for a few weeks no problem.
Has anyone else come across this or any clue what fan it refers to?
Many thanks
SH
Re: 206cc 1.6ltr low power to fan causes No start
Can only be cooling fan.
So is the diag kit Peugeot compatible... ? Many aren't hence the misleading error code(s)
shimerin
Post by shimerin »
Hi, Not sure which software he uses but I am getting it on a Peugeot stand alone this week.
Many thanks
