idle problems
micky1
idle problems
hi guys got a 2005 2o6cc it has not been started for a couple of months had the battery off it and just started it today and the revs go up and down on there own and it wont respond to the accelerator pedal but if you switch it of and back on everything is okay any suggestions thanks micky1.
- Spitfire6
Re: idle problems
Is the engine "fault" light on?
G6SBH.
G6SBH.
Re: idle problems
Try a BSI reboot.
