esp
micky1
esp
Post by micky1 »
hi guys micky1 here again forgot to ask what is the esp button on a 2005 206cc convertible for as don't have manual yet thanks.
Re: esp
It's for switching the ESP/ASR off if stuck in soft ground or snow, to help you get moving again.
http://public.servicebox.peugeot.com/APddb/ for the online manual. Select language, then car, model and year.
MartinMax
Re: esp
Post by MartinMax »
micky1 wrote:hi guys micky1 here again forgot to ask what is the esp button on a 2005 206cc convertible for as don't have manual yet thanks.
It's for making 11's on the street... ;)
2001 206cc 2.0 S16
Spitfire6
Re: esp
Post by Spitfire6 »
is ESP an HW update or available as SW only on ABS cars?
Cheers,
Iain.
G6SBH.
Re: esp
According to the SEDRE, the ESP model additionally has an ESP accelerometer gyroscope as well as the ESP switch button, and the ESP ECU is different to the ABS ECU.
Spitfire6
Re: esp
Post by Spitfire6 »
Thanks IanL.
G6SBH.
Re: esp
FYI- ESP stands for Electronic Stability Program, (Basically traction control)
MartinMax
Re: esp
Post by MartinMax »
Capncol wrote:FYI- ESP stands for Electronic Stability Program, (Basically traction control)
Actually, these are two systems:
Stability control will try to correct understeer or oversteer by acting on the engine and breaks (by braking individual wheels as necessary)
Traction control will lower the engine output to prevent wheel slip, that's why it has to be disabled if you want to do a burnout (or lay some rubber).
So, two different systems working together.
Unfortunately, my CC does not have either of them, but on my other car (Opel Zafira), one press of the button disables traction control and holding the button for 3 sec disables ESP.
2001 206cc 2.0 S16
