catalytic converter support bolt
ben2601
Post by ben2601 »
I've recently bought a 2003 206cc.
The Pipe has snapped at the bottom of my cat it turns out there was never a bolt in the support bracket that holds the cat to the engine at the end of the pipe. Does anyone know what size bolt I need for this?
Re: catalytic converter support bolt
You don't say which engine you have. If it's the 1.6 petrol TU5JP4, the part is described as (MUL)SELF LOCK SELF-TAP SCREW
10 X 150 - 70
and the part no is 6923 09.
If you have one of the other 3 engines, post the last 8 digits of your VIN, or you can look it up yourself at http://public.servicebox.peugeot.com/pages/index.jsp. (*register as an independent)
ben2601
Post by ben2601 »
Thank you yes it's the 1.6 petrol. I've searched on google is this the screw I need?
I assume so, as it's the correct part number.
