206 verve 2006
Nottmtrucker
206 verve 2006
Post by Nottmtrucker »
I recently had flat battery due to leaving lights on. Jump started ok but now engine management light came on. It also went into limp mode, I stopped turned the engine back on, runs ok but engine management light remains on. Any suggestions?
Many thanks in advance
Re: 206 verve 2006
Read the fault code(s).
Actually, it may be false code(s) caused by the electrical shenanigins, so try resetting the code(s) after recording it/them. If it/they do not come back, that was what it was.
Re: 206 verve 2006
It might go off on its own if you use the car a few times. In other cases it will need to be reset.
