Boot lid not opening.
MelidenBob
Post by MelidenBob »
Hi to all,
I hope someone can give an idea about this old problem.
Replacing the back axle in November, as part of the job I used the boot rails as a way of tying up the calipers out of the way whilst changing the complete axle, for this part it worked great. To make life easier we had the roof open, but then the rain came and unfortunately I tried to close the roof whilst it was still tied down. (What a total pratt!) Realized quite quickly and took off the cord, but too late, the roof wouldn't close. Thanks to this forum found out about the manual close and did that.
Assuming an issue with the pump I firstly changed the fluid, still nothing. The fluid that came out was very black, and after trying it the new fluid did change slightly darker, which seems to show it is pumping. I then got a pump from a breaker and tried it, exactly the same result. At all times the pump is heard running and the locks release and lock on the upper boot lid. Thinking it is to do with the upper lid lifting I then got a pair of rams and changed them, but no joy.
I did think that as I have a pair of the rams spare I might look at trying to renew the seals in them.
The last thing I am debating are the sensors for the boot lid, if they are saying it is locked would they stop the action but still let the pump run?
Any help would be greatly appreciated. :love-thx:
Re: Boot lid not opening.
If the pump is running, but you get no motion, a likely cause is the "electrically operated valve" - see http://www.peugeot206cc.co.uk/viewtopic.php?f=5&t=12920 at 2.30.
A previous poster had success by removing the valve and then replacing it - the guess is that it had stuck.
Spitfire6
Post by Spitfire6 »
sounds like you need a pp2000 to fix the original fault?
Cheers,
Iain.
G6SBH.
MelidenBob
Thanks for the replies. Looked at the video and it is brilliant, so clear in the explanation of just how it all works, definitely one I will be watching again. Regarding the valve, as I actually changed the pump complete with the valve I am doubtfull but I will definitely check, I have the original so I might be able to check it with a voltage supply?
The PP2000, the nearest person on Planet Map is in Wrexham. Rather than go to Peugeot I have a spare laptop so I have ordered a PP2000 cheapy, maybe it will work, reading views on them they are mixed.
Spitfire6
Post by Spitfire6 »
If you are ever driving near Burnley.
G6SBH.
I assume you checked the pressure relief valve on the pump is tightly closed?
You are not too far from Telford, so, if you are stuck, these people are the absolute roof experts - http://frenchdiagnosticservices.com/peugeot-cabriolets
