roof and window issue
mightymetro
Post by mightymetro »
Hi, Our 206cc roof has stopped working today.
The blind is in place and fuses are okay, when we unlatch the two roof latches we get the usual bong, This is when the issue starts, when you press the roof switch we get the failure beep beep beep, and when we try and lower the windows we also get the beep beep beep. Once we re-latch the roof the window switches work again.
Any ideas please because this is really doing my head in now.
Chris.
Re: roof and window issue
Possible causes:
Lack of hydraulic fluid - check reservoir level.
Defective electrically-operated valve on pump.
Defective pump relay
Hydraulic circuit depressurising valve not screwed in tight
Spitfire6
Post by Spitfire6 »
PP2000 needed to fault find & reset the roof.
Cheers,
Iain.
G6SBH.
Blind not pulled across or microswitch in blind hook not showing blind is across?
