Hi All. 2005 model 1.6 petrol Auto
Heater blowing cold air. On the motorway yesterday (3 hour run from work) I noticed the temp gauge was high for twenty seconds then dropped to normal/low for twenty seconds, then back up to high again, and repeated the cycle all the way home,
Header bottle level is between min & max. Nothing unusual from exhaust pipe or on dipstick,
Engine does not seem to be overheating, but blower is cold and the gauge needle is up and down like a fiddlers elbow !
I unscrewed the bleed screw on the heater pipe and lots of fluid came out but no "hissing air noise"
Heater blowing cold, Temp gauge moving up and down
RetroPKR
Re: Heater blowing cold, Temp gauge moving up and down
There are two bleed screws - you need to check both.
Just a guess, but your water pump may not be working. You will still get some engine cooling by convection. I have heard of the pump shaft fracturing, or the teeth on the pump impeller corroding away.
If you do decide to check the pump, you may as well change the cambelt at the same time.
RetroPKR
