Is there a special fitment aerial needed for the 206cc ?
Just bought a genuine 206 aerial and it won't screw into the fitting and the base is too big.
Cheers
Aerials....
Re: Aerials....
This is what you want - works perfectly - probably cheaper than the genuine (can you return that?):
https://heynershop.co.uk/car-radio-aeri ... 37009.html
What has probably happened is that the base has an adapter screwed into it and perhaps stuck so it won't come out, so you will need to use the universal antenna without its adapter.
