Oil temp arrow is not moving
fellu
Post by fellu »
Hiya ! Motor: 2003 1.6 16v petrol.
For some reason oil temp(?) arrow is not moving on dashboard. Is it some sensor(?)
Re: Oil temp arrow is not moving
What is it pointing to?
fellu
Post by fellu »
0 :/ at the bottom, not moving at all.
Probably a broken wire between the oil sensor, the engine compt. fusebox and the BSI, or plug/socket in the path, or it could be the sensor, which is a combined pressure and temp sensor. Outside chance that the needle is stuck.
fellu
Post by fellu »
IanL wrote:Probably a broken wire between the oil sensor, the engine compt. fusebox and the BSI, or plug/socket in the path, or it could be the sensor, which is a combined pressure and temp sensor. Outside chance that the needle is stuck.
thx for the info! what is the color of pressure and temp sensor?
It takes quite a while for oil temp to register after running engine.
