Peugeot 206cc Gas recyling pipe
Salter
Post by Salter »
Can anyone recommend any cheaper places to try for the following pipe.
No.7 in the pic...
Peugeot are quoting nearly £ 70 for it...
Re: Peugeot 206cc Gas recyling pipe
Can you not replace with Hi temp hose?
Salter
Post by Salter »
Ok thanks for the reply, I will give it a try....
Salter
Post by Salter »
Has anyone got links or suggestions for the pipe to use ? I think the pipe is 21 ID and finding a hi temp replacement pipe hard to find ?
Cheers
Have you tried local scrappers?
Salter
Post by Salter »
Cheers, I have tried the scrappers, only found one local but the pipe was already perished.
I'd buy the one from Peugeot then.
