right battery?
sirdmark
right battery?
Post by sirdmark »
Hello everyone,
as my predecessor abandoned the project because he bought a camper van and mostly lives in Spain now, his battery seized to work and the electronic went haywire. He just managed to reboot everything but didn't want to spend money on a battery. Hence, the one in the car doesn't fit, as he just took one he had lying around. So I have to order a new one. This is the one I intend to order:
YBX5012 Yuasa Silver High Performance Car Battery 12V 54Ah HSB012
Any objections?
Thanks Luke
206ccAllure,1.6ltrpetrol,03plate
Re: right battery?
That'll do nicely :)
Do follow the correct procedure when changing batteries:
http://www.peugeot206cc.co.uk/viewtopic ... 23&t=13473
Spitfire6
Re: right battery?
Post by Spitfire6 »
I was going to say that battery is too thin. I thought it was 243mm wide?
Mine is 540 CCA EN. I tested it a week ago. I have lost 10 CCA. It must be five years old as I took it off the spitfire.
Off to measure mine now!
I Only buy Banner Pro batteries
G6SBH.
Spitfire6
Re: right battery?
Post by Spitfire6 »
Is the 1.6 a smaller battery?
243 x 175 x 190 high. A good volume for performance and cost.
G6SBH.
Re: right battery?
Yes, the 1.6 battery is 207 x 175 x 190mm. Mine is secured with a clamp on the side, not a strap across the top.
sirdmark
Re: right battery?
Post by sirdmark »
Thanks for the answers. I couldn't take the measurements as it was raining yesterday evening but I also have a metal strap over the top of the battery, just as on the photo from spitfire. I will try to measure today. The brake discs are on their way from Germany now and my friend will come up from Bristol to help with changing them. That is what I call true "love" ;-). Luke
sirdmark
Window switch repair
Post by sirdmark »
Hello everyone, as I had a faulty window switch in my 206cc I ventured on youtube and found a video :
"Peugeot 206cc windows colse doesn't work, problem resolved!" by a German Guy, hence the spelling. I followed his advice. Be careful, when you take the switch apart. There is a tiny spring for the rear mirrors which you don't want to lose and found the rubber mat between the plastic switches and the contacts was loose and the whole switch was dirty. Cleaned it with the help of a toothbrush and some acetone, fixed the rubber mat back into position and put the switch back in. Presto, everything works like a charm. Luke
sirdmark
Re: right battery?
Post by sirdmark »
Hello Ian,
it seems to be that the case is much bigger than the actual size of the battery but the limiting factor is the metal strap. The above mentioned Battery is the maximum physical size you can fit with the strap. It now looks like in your photo apart from me having a different set of contacts. I have the screwless ones. It all went well and I hope the 4ah more juice will make a difference. Luke
Spitfire6
Re: right battery?
Post by Spitfire6 »
What was the code of the battery you have?
G6SBH.
sirdmark
Re: right battery?
Post by sirdmark »
Hello Spitfire6,
the battery: YBX5012 Yuasa Silver High Performance Car Battery 12V 54Ah HSB012
from Tayna. You will find all the data on their website. Fits perfect and of course looks like in your photos as Ian doesn't have any Photos in this post. I also changed the bulbs in the central display which means I am able to see what it shows. What an achievement ;-)
Spitfire6
Re: right battery?
Post by Spitfire6 »
Happy days! I always keep by illumination on low now to prolong the hassle of changing them or the others....
G6SBH.
