Plugs & Coil
Claudia cc
Plugs & Coil
Post by Claudia cc »
Hello,
Advice needed on which Plugs & Coil pack combination needed to replace with please, The old girl is poorly today with "P0303" on Planet,
54 reg 2ltr.
Thank you,
C Coop's..
Oh also, what spark plug socket do i need in this engine?
Re: Plugs & Coil
Bosch plugs .. I fitted Super 4s to ours and it was so much better. Just avoid NGK plugs and you can use any coil pack. I fitted one off a 138hp GTi (same engine) but can't remember the make (wasn't sagem .. I'd remember that!)
Claudia cc
Re: Plugs & Coil
Thanks Gazza, would that be the 'FR78X' (£3.05 each at GSF) (Peugeot Plugs £4.00+vat)
Whats the recommended Coil Pack to go for? (Peugeot £104+vat)
There seem to be loads of them from £40 odd up to £150...
Thank you..
Re: Plugs & Coil
FR78X is what I fitted.
I got my coilpack second hand and several years agos so can't quote on prices/makes. Try the forum's Search function
vknight
re;no negative at injectors no flickering pulses
Post by vknight »
hello,i have just noticed my pug 206cc 2.0cc 2003 injectors are not pulsing with a test lamp pushed into each wire at the connectors.both wires light up my test lamp on each injector,engine lacks power with slightly un-even idle.put new plugs in 'ngk' plugs,i read that injectors operate by using a negatibe pulse which makes them pulse with a lamp tester.my injectors wires light my test lamp through all injectors.does this mean there is no earthing taking place across all my injectors?.thanks for any replies.vincent.
Re: Plugs & Coil
NGK plugs are often a problem with the 206s ignition system. As stated above, use Bosch FR78X.
Re: Plugs & Coil
A test light doesn’t usually work on injectors. You need Noid lights
Re: Plugs & Coil
A test light doesn’t usually work on injectors as the pulse width is so small. You need Noid lights
