windows not closing after putting the roof back up.
ted61
Post by ted61 »
Hi all, any help here would be much appreciated.After putting the roof up,I get the beeps....if i cycle through putting it down and up again several times ,the windows usually finally respond...at any other time they work fine.I do get the "bong "confirmation of roof closed. Thanks, Ted
timanderson
Re: windows not closing after putting the roof back up.
Post by timanderson »
After the roof goes back up, can you close the windows with the window buttons? Or are they stuck open?
Tim
ted61
Post by ted61 »
They stay open..and as soon as i push the buttons to raise them i get the beep beeps.
It may be that one of the roof catch switches (atop the windscreen pillars) has a bad contact. Try spraying into them with contact cleaner. (Don't use WD40 - it attracts and holds dirt. Use lubricant-free contact cleaner, e.g. this)
ted61
Post by ted61 »
Tim I can close close the roof using the relay trick, and yes the windows work, and Ian ,thanks for the tip, I will give it a try...
