Brake lines - replacement advice please
ianP
Post by ianP »
Hi all,
Does anyone have any advice for me when replacing the steel brake lines under the car please?
As Servicebox is no longer available I cant even get an idea from there and I can't see anything useful on a Google search.
I guess the main question, as I can't be bothered to look for myself :roll:, is " how far do they go at the front? Can I "easily" access/remove them from underneath without having to take the entire front end to bits?
Thanks all
Ian P
2005 206cc 1.6 HDi FAP, 2014 2008 1.6 e-HDi, 1989 205GTI 1.6
Re: Brake lines - replacement advice please
Brake lines are never usually that easy as they tend to run up behind the engine/gearbox and between parts that don't normally come off that easy. They have to reach the master cylinders, abs, etc .. and don't normally have a convenient joint as they are fitted at the factory before therest of the running gear ...
ianP
Post by ianP »
Cheers Gazza - didn't manage to have a look this weekend but if they look very buried up front I might refresh the centre and rear sections by putting a joint in.
Ian P
