Hydraulic roof pump
Julie123
Hydraulic roof pump
Post by Julie123 »
How easy is it to change the hydraulic roof pump over, mines leaking as quick as I'm filling it, so bought a replacement, is it a garage job or could I do it myself with the aid of you tube.
Re: Hydraulic roof pump
You can DIY, but, personally, I would let a trusted mechanic do it. Before you bought the replacement, did you find out which part was leaking? It could just be a seal, or even a loose union.
