Engine hesitates between 2000 and 2100 rpm.
Chrisvankalken
Post by Chrisvankalken »
About a week ago the engine of my 206 started to hesitate only between 2000 and 2100 rpm. It happens in all gears. So I decided to take a look at my spark plugs. I soon found a broken and loose spark plug. So I figured, I solved the problem but as a matter of fact; nothing changed! It still hesitates between 2000 and 2100 rpm while accelerating. No warning lights come on and it also isn't always happening. Some days I have no problem at all. Anybody have a clue?
Peugeot 206 CC, year 2002, 1.6l 16V engine, manual 5 speed transmission, no air conditioning.
Re: Engine hesitates between 2000 and 2100 rpm.
Could be a problem in the coil pack
Check the coil pack isn't one that doesn't like NGK spark plugs either (think it's the Sagem version).
Chrisvankalken
The problem gradually disappeared over the last weeks. Could it be the computer had to adjust because of the new sparkplugs? If it comes back, I change the coil pack.
