When driving over 10mph I'm getting bleeping which I think is saying the roof isn't closed.
I've looked at various posts which indicate could be sensors, checked what I could and everything looks fine.
If you press the close roof button you can hear the motor start up as if the roof hasn't finished closing and get the final bong to say roof closed. The car will drive without the bleeping for some time then it will start again so you repeat the close button and it clears.
Is it likely to be sensors or something else?
Bleeping - roof
Johnnyb60
Re: Bleeping - roof
Have you tried giving the micro switches a clean using some electrical contact cleaner.
It sounds likely to me you need to start with the ones on the top of the windscreen were the manual locking levers are.
