Hello,
I want to install this nitrous kit to my CC, but I don't know if my car has the following requirements:
• A vacuum actuated fuel pressure regulator* because this is how the ZEX™ unit regulates/maintains proper fuel pressure at activation.
• A throttle position sensor* voltage output of at least 4.2 volts at wide open throttle (WOT) - because the ZEX™ unit uses this voltage range as a reference point to actually activate the nitrous system.
Could someone help me with this subject?
ZEX Nitrous System
No Friegue
paul_y3k
No Friegue
What should I do then? The thing is that I'm not sure if the pugs have that vacuum system, I'm sure the throttle position can be measured but I need to be certain. Should I buy the Universal Nitrous system by NOS (with solenoids and stuff) which doesn't require the vacuum regulator?
What do you suggest?
[url=http://www.peugeot206cc.co.uk/owners-321-330.html]Owner #330[/url]
Alex LS
You could try asking this question on the PGAC forum if nobody here knows.
http://www.peugeot-gti.net/
