Leaking On drivers side only
neiltaylor5
Post by neiltaylor5 »
I had a leak when i had a cc and after 5 trips to peugeot i disovered why it leaked myself- it was due to door window intermittantly not mating with the roof channel- thus leaving a gap , as i said this happened about 30% of time when the door closed , next time you close you door from outside check it out. I told pugeot (i come origionally from coventry and have a freind who is very high in the peugeot uk pecking order) and he has passed this on, this problem only manifested itself after the so called 're aligning 'of the roof. I believe that the doors need to be set with the roof.
cpowell
Post by cpowell »
My window on drivers side used to have a gap of about 1 inch. At the time Peugeot said it was an adjustment, so I would have to pay. The car was only two years old and I had to contact Peugeot UK to get them to pay for it, as it is clearly a design fault. Well its happened again now!
