Windscreen Wash Reservoir
Alig
Post by Alig »
Just been topping it up...and as soon as I put it in..its leaking out of the bottom :yikes:
I think the reservoir must be cracked. Oh no, not a day trip to the dealers again :(
Ali G
Derek
Post by Derek »
they'll probably tell u u need a new engine :lol:
Derek
Alig
Post by Alig »
I'd better start looking for a new car right away then..how about a new Tigra? ;) :lol:
Ali G
Bri
Post by Bri »
All may not be lost!
Is it all leaking out or just a bit?
Have you had your headlight bulbs replaced recently?
If so, it could be that the filler pipe has not been located correctly. The pipe pulls off to get at the back of the off-side light cluster. If it's not been put back correctly, you might loose a bit of fluid as it fills the resovoir and backs up the pipe.
Might be worth a check?
Bri
[url=http://www.peugeot206cc.co.uk/newowners?id=137]Owner 137[/url]
Alig
Post by Alig »
That is a very good point indeed! Because, yes, I had a quad light conversion done a few weeks ago and even more recent than that - we changed the standard bulbs for Ice Blue's.
I'm off to have a nose!
Thanks - here's hoping its that! :D
Ali G
Bri
Post by Bri »
No problem :) If it's just the filler pipe, I wouldn't worry about it - it will just prevent you from over-filling the resovoir! (is that how you spell resovoir... resevoir?!) :lol:
