Mystery Leak- This Will Trump Every1 Elses
JamieF
Post by JamieF »
Okay People, here's one for you
- Empty car
- Rainy night
- in the morning soaking wet floor in reat passenger footwell..only on the drivers side
Nowhere else wet, no water on anything else..never happened since
any1 else had this? any ideas?
Lyndon
Site Admin
Post by Lyndon »
check around the entire door seals for splits or not seated correctly as i had the exact same problem on my old metro many years ago, finished up removing the seal,using silicon sealant then reseated the seal no more probs :)
or i could be completey wrong :?
Alig
Post by Alig »
Had a similar leak on my cc last year...got in through the roof seal and the juncture of the front/rear window...couldn't work out where it came from initially, then it rained again and you could see the water running down the interior trim. Was also on the drivers side.
Had the roof and doors re-aligned and door seals checked. Interestingly, as the car was in for some other bits, they did a second leak check a couple of days later and it leaked again, so they replaced the seals.
One way to check is use a watering can and pour over the roof..see if water goes down the inside of your windows.
Good luck sorting. :)
Ali G
Dan
Post by Dan »
mine leaks at the drivers side rear, it stops and starts occasionally
