I was registered on here previously, but completely forgotten mu login. Anyway posted some images of my install a few months back but I now have installed a DVD player and screens in the visors.
Thought you might like a look. Hope everyone is okay and you like the install
Subs can be removed yes. Its a bit of a tight fit, but everything will go back to standard if I want it too.
Screens were a pain to fit yes. I had to connect the DVD player and monitor power to the ciggarette lighter power, and run the cables respectively to the relevant parts. The cable for the monitor comes up the inside of the left hand side of the windscreen and accross the top to the monitor. Sounds class running through the amplified system. I attatched it to the lighter socket so that the DVD and screens go off when the engine does...
