I have fitted a Pioneer DEH3730MP CD/MP3 player which works fine but something funny happens with the in-dash display. I expected the radio readout on the dash to disconnect but it has also taken out the time and message system. These are obviously running in the background as they update at ignition switch on but do not change when engine running - the clock stops when the engine is running and then restarts and updates when the engine stops. Messages, such as 'door open', also lock when the engine is started.
I might have to go to a Peugeot Dealer to get the car's computer reset but this would be difficult as the nearest is some distance away.
It is annoying to have the display locked and the lack of an accurate clock is a nuisance. I am hoping that someone will have a solution.
Thanks, in anticipation.
Problem with in-dash display after CD player fitted
CMC-24
reap
you can disconect the stereo from the car wiring and make up your own loom from the ignition+fused.
you need perm ignition feed.
accesories ignition feed
and a good earth(down by airbag ecu under centre console)
and speaker wires you can use from the car loom as they are none multiplexed.
ive seen some stereos wired to the fag lighter/accesories dock on centre console.
- Lyndon
- Site Admin
