Intermittent squeaking climate control unit
China_Blue
Post by China_Blue »
My 2.0 2002 206 has developed an intermittent problem with the Climate control. It usually starts up with the unit, on the passenger side on the centre console, squeaking and the air con fans on reduced power. Sometimes the problem clears and normal full power operation resumes. Other times the squeak and feeble air con power continues for the whole journey. If I put my head in the foot well and listen closely the squeak sounds similar to trapped air in a central heating radiator. Before I start pulling it to pieces or take it to a dealer has anyone experienced this fault before? I'll answer any further questions you have. Thanks.
Col
