Broken Speedo - how to remove it?
lim_walk
Post by lim_walk »
Hi guys i wondered if you can help. Im new to the forum need to know how i can get the speedo out of the dash
My gf's cc's speedo isnt working (everything else is) so i need to get a new set from the scrappy. I will either open up the broken set and replace the broken motor/magnet from the scrappy's set, or get someone to change the milegage on the new set to suit.
PUG quoted me £350+ Vat and labour for a new one
does anyone know how to get the dial set out?
cheers
reap
Post by reap »
are you sure tis a speedo fault? how olsd is your car?
tis normally the vehicle speed sensor on the gearbox that causes that fault,can change anything in speedo when opened neither as its all soldered to a printed circiut board.
think you need to start at the gearbox unless you have deffo been told differant :)
lim_walk
Post by lim_walk »
reap wrote:are you sure tis a speedo fault? how olsd is your car?
its an 2001 shape.
Apparently the stealers have replaced the sensor on the gearbox for aound £40 ish o belive - thats what the misses has said, but it hasnt helped. I assume that is what it was considering the price.
I thought that if i tried another cluster and it worked - for only £30 it was worth the risk of not having to pay £350.
This happened to my megane and i re-soldered a new motor/magnet inplace of the broken one. Saved me a fortune
reap
Post by reap »
try a new speedo,must warn you though,the car will learn the highest mileage,so if your car done 30,000 and the new speedo done 60,000 then thats what we be learnt to the car.:(
lim_walk
Post by lim_walk »
xheers for the heads up. I will try to find a set thats done less mils.
Does anyone know how to take the dials out from the car? Do i have to remove the dash?
Any help would be grateful
reap
Post by reap »
unclick binnicle from bottom and pull off,or pull forward on the top and the bottom should follw,1 t20 bolt on top of speedo,speedo pulls out,5 min job :)
