I am fitting a replacement engine loom. But I can't fit one connector to any where.
Fuse box Delphi BSM B3
Three pin plug. Sits around starter motor.
Grey & white to Pin 2 on Black multiway plug PM1 on fuse box, Earth and Grey & Red to pin 14 on same Black Multiway.
a, What does it do?
b, Where does it go?
*URGENT*
SOLVED - Fuse box Black Multiway Pin Identification needed.
Shaun Lee
02 Pug 206cc 1.6 NFU Moonstone.
Problems to date:
* Roof not working, Gearbox bearing knackered, Wishbones, droplinks and brake discs kaput - All Fixed.
* Rear wheel bearing rumble - TBC
* Engine wiring fried and Immobilser / Eco mode fault......ongoing.
Problems to date:
Enright
Re: SOLVED - Fuse box Black Multiway Pin Identification need
Could be the knock sensor on the back of the engine block - that is near to where the end of the starter motor is. If it is that, it's to detect pinking and send a signal to your ECU, which then adjusts your ignition to stop it from running lean. Note that's all dependant on the "if" though!
BCingU,
Neil.
Neil.
Shaun Lee
Cheers Neil, Your a star. Eventually found it just didn't know what it was for. Got your PM. Just got to get it started now!!
Problems to date:
Problems to date:
