Hope you're all keeping well!
So, my friends 206cc has a few more teething issues (only a slight few!)
Okay, first thing: Tempermental Key Fob.
On first appearance it appears the battery has failed.
It's a 2 key fob type, big chrome lion on one side, on the other you've got the lock button at the top (which also deadlocks it) and the bottom smaller button unlocks it.
I've got 2 of these keys for my same year (52) 406 and mine came apart (to steal a battery for her) quite easily, pulled it apart where it hooks onto a key ring..
Hers? Err not so easily.. It came apart for about 2mm then it just wouldn't separate. Anyhow, I gave up, closed the key back up, pressed the button to make sure I had the dead key (I'd tried that before I even looked at the keys and knew 100% that was the dead key) anyhow, pressed the button and it worked... a minute or so later, again it wouldn't work... again repeated the process as above and it worked again (still working now)
Any ideas as to what happened to the key and why it's miraculously repaired itself?
Ok, problem 2: Lost the radio signal:
When we picked the car up last week the radio worked absolutely perfectly until a day later in the week last week when all of a sudden it's lost signal.
I've checked the obvious things, looked at the aerial connection behind the head unit which appears to be well in there and not worked lose (I thought perhaps due to the severe knocking on the front end it may have come out - which makes no sense as it is still picking up Radio 2) Anyway, that looked fine.
Looked on the aerial outside the car and with mine it screws off and out - hers, well STUCK isn't the word! I was going to get my mole grips and try that....
Any ideas guys?
Help greatly appreciated.......
EDIT: Friend is now threatening to force me to listen to her One Direction CD until I get the radio sorted so please guys and girls - help me asap!
