Warning came on this morning in cold frosty (minus 2 Celsius)
stopped, pulled over. Car off, turn on car, no problem.
I didn't notice any bounce on temp gauge or anything. Coolant levels good.
Is this likely to be a sensor? no way car was to hot. when I turned car back on temp was v low. i.e cold.
(my searching a came up with this happen in heat and at idle stuck in traffic which doesn't apply here)
Cheers in advance.
Karl
coolant temperature too high warning
Re: coolant temperature too high warning
Karlos_junior
2004 • 1.6L • 206 • 4spd Auto • 126,000km's.
My question would relate to any 206 model I would have thought but info as requested.
Thanks Karl, at least we know its a Peugeot 206 hatchback now. Is it the single OHC or the double OHC engine?
If someone on here has experienced your symptoms then no doubt they will chip in with their suggestions. We cater here specifically for the 206cc owner. The 1.6 206cc petrol engine is the DOHC in our cars.
From your description I would suspect a faulty temperature gauge/sensor but I wouldn't rule out a battery at the end of its life. When it is frosty here in the UK spurious warning signals are often an indication that the car's battery is beginning to fail. How old is your battery?
Furthermore, when your timing belt was renewed was the water pump renewed at the same time in line with best practice? That could rule out circulatory issues.
Karlos_junior wrote:Warning came on this morning in cold frosty (minus 2 Celsius) Was this on start up? soon after start up? after driving for a long time?
stopped, pulled over. Car off, turn on car, no problem.After allowing it to cool or straight away?
I didn't notice any bounce on temp gauge or anything. Coolant levels good.What mix of antifreeze (if any) & when was it last changed?
Is this likely to be a sensor? no way car was to hot. when I turned car back on temp was v low. i.e cold.Could be but please answer questions above
Cheers in advance.
Karl
Have had this on the 1.4 hdi ... Sensor failing.
