Front seat problem
Front seat problem
My passenger seat has gone wrong. It slides forward and back but does not lock into place. The slide forward/back release lever will not move. The seat back is jammed tilted fully forward, and the control levers at the sides have movement, but do not release the seat back. :oops:
Any suggestions gratefully received.
Re: Front seat problem
Ian.
If you use the search facility for *seat runners* There are a load of similar probs and various methods of fixing.
Thanks for the reply, Col. There was one post with the same symptoms, but no cure.
However, I am greatly indebted to Reliable406 on the Peugeotforums.com site for his sage advice which resulted in a complete cure :thumbs:
Taking in what he said about turning the shaft in the opposite direction to what you'd expect, I pushed down on one handle and stood on the other, whilst pulling back on the headrest. Took a chance on the plastic handles being strong enough, but they were :)
Click, and it was in.
I hope this helps anyone else who has the same problem.
Thanks for the feedback
