Cv joint replacement
JILLYPIPS
Post by JILLYPIPS »
Hello you lovely people
You've helped me out so much in the past I'm after your knowledge once again
CV joint needs replacing. Is this possible without removing drive shaft
02 plate
Re: Cv joint replacement
It won't be a quick or easy as you don't have much room to work in. In the end it is probably quicker and simply to pull the driveshaft. It will probably pop out anyway if the passenger side ...
You should really change these in a clean environment as you don't want to get dirt in there or it will wear out quicker.
JILLYPIPS
Post by JILLYPIPS »
Hi gazza82 thanks for that. Drive shaft out it is then :thumbs:
