Ingnitioon-integrated phase detection
prondebele
Post by prondebele »
Hallo people I'm new.
I own a Peugeot 206cc 2001, 1.6 Litre. Car starts and cuts in the morning, and it becomes ok after 4 to 5 attempts, took it for a scan and these were the results.
1. Description: Ignition-integrated phase detection. - Intermitant fault
2. Vehicle speed sensor coherence - Intermitant fault.
How can I solve this issue.
Peugeot 206cc 1,6Litre, 16v 2001
Jesus saves the worst sinner. Call upon him today
Re: Ingnitioon-integrated phase detection
Maybe try another coil pack?
prondebele
Someone suggested Crankshaft position Sensor. Googled and got this info below:
1. Issues starting the vehicle
The first symptom that is most commonly associated with a bad or failing crankshaft position sensor are issues starting the vehicle.
2. Intermittent stalling
Another symptom commonly associated with a problematic crankshaft position sensor is intermittent stalling.
What did you have it tested on? If it wasn't PP2000, the PSA diagnostic, it may not be the exact issue.
I've tried a few on our 2001 on can get different results. I'd only trust pp2000 or a PSA specific diagnostic.
Pro scanners are fine, it's the cheapy ebay ones tha are suspect as they only read the generic EBD code. A good pro scanner will read manufacturers codes as well.
Anyway-change the coil pack
Slo
Post by Slo »
Reach down the back and disconnect the speed sensor and see if theres any improvement.
prondebele
Speed sensor??? You mean it will solve ignition problem?
prondebele
While waiting for a new coil pack ordered abroad, the car all of a sudden is starting normally. No problems.
My speedoneter is still on and off, same with the odometer. Sometimes works well then its off.
That doesn't sound like it's a coilpack problem.
Check the engine ECU for water ingress/dirt, especially in the connectors. Spray with contact cleaner before replacing connectors.
gazza82 wrote:That doesn't sound like it's a coilpack problem.
He has more than 1 prob. IPD and VSS
