Interior Light
gtb5
Post by gtb5 »
Does anyone know any safe way to take off the interior light cover to change bulb? Just ply it off with a flat screw drive?
Tyce
Post by Tyce »
I suggest that you don't use a hammer! :grin:
Why has your bulb gone?
Maybe pop into your local car accessories place and have a look at the 206 DIY manual... I'm sure the light fitting has got to be the same!
Tyce
rob
Post by rob »
a thin flat bladed screw driver from the side of the clear bit should allow you to drop it down to replace the bulb
I prefer to use the screwdriver from the right hand side (dont thinkit makes a difference)
<font size=-1>[ This Message was edited by: rob on 2002-02-27 14:17 ]</font>
Rob
gtb5
Post by gtb5 »
Thanks for your suggestions and I'll give it a try, just like to replace the bulb with a brighter one.
rob
Post by rob »
try taking your shades of when reading the map at night :grin:
Rob
