Tyre Pressures
The_Inspector
Post by The_Inspector »
I've been wondering a while what tyre pressures I should have on my CC SE. I couldn't find anyting in the manual, but finally found a sticker when I opened the door. This said 2.3Bar, which using a calculator comes to aprox 33.3 psi, which seems a bit low.
I went to check my pressures this morning and found that they have been around 42psi since I got the car!!
What tyre pressures do people recommend? Do I go with the low 33 or around 40? Or is a comprimise in order, maybe 36?
Any feedback would be appreciated!
thanks
Alex LS
Post by Alex LS »
I'm driving a Fiesta at the moment, and the 'correct' pressure for up to 3 people is 32 front and 26 rear. This didn't stop the dealer setting them all to 36 when I had it serviced though...
If the label says 33, it could be correct :smile:
Robbie
Post by Robbie »
I too had a much larger pressure in my tyres from the dealership when I checked- even more than it should have been for full load. Wondered if there was a reason for this? Yesterday, I finally got round to setting mine at 2.3 bar as shown on the door sticker.
rob
Post by rob »
Me and Melanie both found that 32psi is the best setting for tyre pressure. The 2.3bar seems a bit high still and can make the car 'skittish' even in the dry.
1.5psi seems to make quite a lot of difference.
Rob
Julia
Post by Julia »
While on the subject of tyres......
I have had my CC almost a year and have noticed VERY bad wear on the tyres. I am sure I will be having to replace them soon :sad:
Has anyone else (similar age CC's) noticed this? (or is it my driving)
Does anyone know how long the F1's last??
Is this norm?
[img]http://www.addis-welt.de/smilie/smilie/simpson/Smilie04sim.gif[/img] [img]http://www.addis-welt.de/smilie/smilie/simpson/Smilie03sim.gif[/img] [img]http://www.addis-welt.de/smilie/smilie/simpson/Smilie06sim.gif[/img] [img]http://www.addis-welt.de/smilie/smilie/simpson/Smilie07sim.gif[/img] [img]http://www.addis-welt.de/smilie/smilie/simpson/177.gif[/img]
rob
Post by rob »
is this one the indside or outside edges.
If so go and get the tracking AND THE CAMBER checked or it will just continue to destroy tyres.
Rob
Julia
Post by Julia »
Its not one side or the other, or not that I have noticed.
I will have a good check.
I have a feeling it is to do with the speed I drive as when I had the rear passenger side tyre replaced (had 3 nails in it!) The tyre man commented on the tread on the tyres and said "cor you must drive fast!"
Any other speed demons out there???
rob
Post by rob »
are your tyre pressures correct.
I would suggest one of those digital tyre pressure gagues as the garage ones are usually way out (and that can be dangerous)
Rob
Julia
Post by Julia »
You expect me to check the tyre pressure?
Isn't that what a man is for??? :lol:
I will get someone to check them and have a look!
I still can't get rid of the squeaky brakes - thought my free mouse would have given up on that by now! :rolleyes:
koppers
Post by koppers »
I race a colleague after work some time ago before I lowered my 206cc. He have a Volvo V60 T5 and to avoid both a trip to another world, I had to slam on the brakes down from 185km/h to 60km/h - the reaction from the car almost give me a heart attack!
It feels like the worst roller coaster trip I ever had - the care move left-right-left-right for almost 5++sec before it stabilize.
I do check the tyre pressure - same as in the book, then I lowered the car - problem still there but less loose-jointed but still its scare the shit out of me when I slam the breaks.
Any other suggestion than tyre pressure?
Jan Tore Kopperud
JTK, www.komplett.co.uk
Robbie
Post by Robbie »
Koppers- how about killing your speed and not yourself- that'll sort out your problem,
cheers,
Robbie :smile: :smile:
