Com2000?
Carly
Post by Carly »
About a week ago my ccs right indicator stopped working. I noticed it because when i indicated right i got no 'click click' sound and my green arrow was not flashing on the instrument display and when i got out of the car i noticed the indicator on the outside wasnt flashing either. I took it to Peugeot who told me the Com2000 had broke and fixed it in about half an hour, but what exactly IS the Com2000? Is it something silly and simple or was i about to be blown up if i hadnt noticed there was no 'click click'... anyone know?
Ian_R
Post by Ian_R »
it must be some controller that does a bit more than the indicator. my indicator stopped working a little while ago and was the com2000 was replaced recently. now the warning sounds are in all in a different tone.
toot
Post by toot »
My tripmeter button stopped working, they fixed that by replacing the com2000 too. Must be some sort of central electrics system, the heart of the multiplexing perhaps :)
[url=http://www.peugeot206cc.co.uk/newowners?id=404]Owner 404[/url]
Huu
Post by Huu »
its that large switching block (black ring surround the base of the steering wheel) you will see it when you remove the cover, which contain all the electronic cables stalks, radio remote and the little speaker. usually they replace the whole block when something goes wrong in those area.
Mr_AWOL
Post by Mr_AWOL »
I had mine replaced ane the indicator clicks are the same, maybe slightly quieter (they were always really quiet anyway)
Is it just mine or do all cc's have indicator clicks that you cant actually hear above 30mph?
Huu
Post by Huu »
yeah quite on mine too, when roof down sometimes i forgot to switch them off after changing lanes... damn embarassing sometimes
clarelee
Post by clarelee »
The heart of the multiplexing is mostly referred to as the BSI or Body systems integration unit (sometimes referred to as the Built in systems integration unit) which are mostly supplied by Siemens, it is the plastic box with a few fuses and wires connected to it behind the panel under your steering wheel.
I would never had guessed that this Com2000 was associated with the steering wheel, It would be nice if tghe Pug dealer had clarified themselves when you picked the car up instead of using jargon?
Craig Atkins
Post by Craig Atkins »
Ah, this would explain why my door open/warning tones have changed from nice beeps and 747-esque dings, to a nasty sounding beep noise.
I had to have the indicators fixed by Pug as turning right didn't always work, and needed a bit of an extra 'push' on the stalk..
I was hoping the sound changes were because they'd flashed the BSI, and that they might go back to normal after the next BSI flash. :cry:
'02 206cc SE
Black Paint
Black/Red Leather
NICE! :)
