THIS RECALL COULD EFFECT ALL RIGHT HAND DRIVE 206's, INCLUDING THE CC built up to Feb 2002..
This is NOT Just a Coventry productionbased problem as stated in the national press.. My CC is affected and will be modified this week..
All dealers have been supplied with parts and can carry out the procedure NOW...
This is the official Peugeot Document: You will need to quote the last 8 digits of Ur VIN number starting with 4*******
SAFETY RECALL FOR PEUGEOT RIGHT HAND DRIVE 206 MODELS
CODE: X3K
Code Description of Incident
X3K It is necessary to exchange the two clevis pins on the brake
pedal system to avoid any risk of loss of braking. Peugeot Motor Company have
experienced a limited number of incidents where one of the pins
has not been locked properly during fitting.
A dedicated 206 Recall Helpline - 0845 60 206 206 has been set up BY PEUGEOT to deal with customer enquiries.
The helpline opening hours are as follows: Mon – Fri : 8.00 – 20.00
Sat : 9.00 – 17.00
Look here http://206infoexchange.proboards22.com/ ... 1068760165
Not a surprise
But in summary:
Peugeot has determined that there is a fault with the brake pedal clevis pin retaining clip(Fitted at the top of the brake pedal). This pin wears in normal use and eventually the clip falls off, the pin drops out and the result being Total brake failure.This campaign will be released to the general public on the 24/11/2003 and will effect EVERY 206 made to date, with the exception of the last months build. All dealers will carry out this repair while you wait, it will take about half an hour to do, and no Peugeot agent is allowed to refuse any 206 owner from having the recall done there and then.
