SAGE HELP
wheel repair it
Post by wheel repair it »
Now then my friends,any of you lot know anything about SAGE accounts system,just need some info on removing a credit note from invoicing section
thats it really
THANKS guys and girls
1.6 Agean with pearled alloys,spats,alloy hoops,ecosse vents,windstop,phone kit,cd changer and K&N filter.(thanx to Derek,Lyndon,Hert62)
www.wheelrepairit.com
2003 KARTING CHAMP(now the proud owner of a NHS wheelchair)
col
Post by col »
Used to work for Sage so fire away matey!
Colin
[url=http://www.peugeot206cc.co.uk/newowners?id=126]Owner 126[/url]
For sale- 17" Miglia Alloys. pm me if your interested
bif
Post by bif »
PM if you want I am a Chartered Accountant who deals with Sage all the time.
That's my secret out in the open
:oops:
http://badassbuddy.bolt.com/images/buddies/badassbuddy_com-adhd.gif
Lyndon
Site Admin
Post by Lyndon »
ah aha haha ha :oops: (sorry,few too many :lager: :lager: )
carl
Post by carl »
Surely you don't ever "remove" a credit note? If you want to cancel it, just issue an invoice for the same amount. If it gets confusing, you can always then print out a statement and check the total is zero.
wheel repair it
Thanks chaps,all sorted
Carl,was thinking of doing it your way but thought there must be a better way as sage is ment to be so smart,but no,so ive just added another invoice for same amount.
Bonkers,
Mr_AWOL
Post by Mr_AWOL »
Just go into file, maintenance, corrections, find the offending credit note and cancel away. (think its something like edit, delete)
Sorted
carl
Post by carl »
I don't think you can actually delete invoices and credit notes using file maintenance.
Mr_AWOL
Post by Mr_AWOL »
Course you can - its only journals that cant be deleted or edited
carl
Post by carl »
IIRC I tried doing this, and although it deleted it from the list of transactions the invoice was still in the list of invoices. Had a similar problem when I put the wrong date on an invoice once -- even if I changed the date of transaction in File Maintenance, the invoice still printed out with the wrong date on it.
Bear in mind I'm still using v6.02 though...
Mr_AWOL
Post by Mr_AWOL »
Dunno.
I use V10 and had to walk someone through this today - worked okay on my machine and they haven't called back, so hopefully all is OK.
Unless ur using the SOP POP BE BA WOP side of things - i only deal with the actual financial data in the nominals, so am more helpful for people entering handwritten or word generated invoices than people using the sage invoice generating method. i tend not to care what mayhem i leave in the invoicing side of things - its not as if you are going to re-print them anyway :)
On the subject of sage anyone know how to stop v10 bringing up the codes in 'analyser' mode by default when you click the 'nominal' tab? i always have to click to view by list because my COA are always so ballsed up where i add codes left right and centre, and even if i didn't the analyser doesnt show them all anyway. Its only a matter of clicking a button, granted, but to have to do that EVERY time i want to see what some idiot book-keeper has put in a nominal? gets right on my tits!
